This article helps you:
Analyze multi-currency revenue data
Understand how Amplitude converts derived properties
Manage project settings
Currency conversion lets you analyze multi-currency revenue data in Amplitude. With currency conversion, you can:
Currency conversion is available on Enterprise and Growth plans. Go to Pricing for more details.
You can control where you view currency-converted data throughout Amplitude. Target currencies are configurable at the project level through project settings. This means that you can use both converted and non-converted values for $revenue and $price fields. You can also:
$revenue and $price fields or map your own custom fields (or cart properties) into the conversion logic.To enable currency conversion, you must send the $currency property as a 3-character ISO 4217 code such as USD, EUR, and so forth alongside your revenue-related data.
Amplitude provides two out-of-the-box (OOTB) derived properties that let you view currency-converted data. These OOTB derived properties are:
These derived properties are only applicable to events containing both $currency and either $revenue or $price fields.
You can find these properties by going to Data > Properties > Derived. They appear as read-only fields and you can use them for filtering, grouping, and aggregations.
Converts the $revenue field into the project's target currency using the $currency field as the original currency code for the received $revenue.
CURRENCY_CONVERT(PROPERTY("$currency", "event"), PROPERTY("$revenue", "event"))
Converts the $price field into the project's target currency using the $currency field as the original currency code for the receive $price.
CURRENCY_CONVERT(PROPERTY('$currency', 'event'), PROPERTY('$price', 'event'))
If you are using $Cart Properties or if you don't use $revenue, $price, or $currency fields, you can create custom derived properties with which to apply currency conversion. This requires project-level currency configuration.
For example:
Adding a derived property to currency convert the custom $revenue or $currency field.
CURRENCY_CONVERT(PROPERTY("_currency_", "event"), PROPERTY("_revenue_", "event"))
And then adding the derived property to currency convert cart properties.
CURRENCY_CONVERT(PROPERTY("_currency_", "event"),PROPERTY("products.revenue", "event"))
You can configure the target currency to which derived property revenue fields in the project settings.
You can select both OOTB and custom derived properties when you are building charts..
When viewing the chart, both the original revenue value and the currency-converted value are available.
September 22nd, 2025
Need help? Contact Support
Visit Amplitude.com
