This article helps you:
Understand how Amplitude defines and tracks user sessions
Learn how to best incorporate sessions into your analyses
In Amplitude, sessions are a useful metric for understanding the frequency and duration of your users' engagement with your product. The most direct way to build a session-based analysis is with the User Sessions chart.
A session is the period of time a user has your app in the foreground or has your website open. The specifics differ slightly between mobile and web applications:
setMinTimeBetweenSessionsMillis(timeout), where the timeout input is in milliseconds.Amplitude automatically generates a session ID for each new session; that ID is the session's start time in milliseconds since epoch (also known as the Unix timestamp). All events within the same session share the same session ID. If you are using Amplitude's SDKs, this happens automatically. If you send data to Amplitude through the HTTP API, explicitly set the session ID field to track sessions.
To count the number of sessions, Amplitude filters for events marked as "active," then applies the project's session definition onto the filtered events.
Amplitude uses that session definition to group user events into sessions, then count the total amount of grouped up sessions.
For more information about setting a project's session definition, review Manage Organizations and Projects.
By default, the setting in Amplitude for the session property is session ID. All events with the same session ID and the same user ID are grouped into the same session. The session ID doesn't need to be unique across multiple users. You can also change the property you use to group sessions.
As noted above, session IDs for events sent through the Amplitude SDKs are automatically generated and managed. However, for events sent through the HTTP API, Amplitude defaults to a session ID of -1. This means it excludes the event from all session metrics.
Events included in the same session are connected with a blue line, as shown above.
Amplitude assigns a session to a specific date based on its actual start time. The start time must fall within a chart's selected date range in order for Amplitude to include it on that chart.
For example, consider a session that begins on May 17th at 8:00 PM and ends on May 18th at 1:30 AM. This session appears on charts where the selected date range includes the date on which the session began. In this example, that date range can begin no later than May 17th, and end no earlier than May 17th. If the chart's date range begins on May 18th, this session doesn't appear on the chart, even though the session was still active on that date.
By default, Amplitude tracks Start Session and End Session events using the beginning and ending times of each session by session ID. Amplitude also uses session ID to calculate session lengths. If you use session IDs, Amplitude doesn't add extra events to your monthly event volume limit.
If trackingStart Session andEnd Session events is critical to your analysis outside of session lengths, you can turn on tracking for these events by adding this line of code before initializing the SDK:
For Android:
Amplitude amplitude = new Amplitude(new Configuration(apiKey = AMPLITUDE_API_KEY, context = applicationContext, trackingSessionEvents = true, ));
For iOS:
[Amplitude instance].trackingSessionEvents = YES;
For Browser:
amplitude.init(API_KEY, OPTIONAL_USER_ID, {
defaultTracking: {
sessions: true,
Important Notes:
End Session event is sent at the start of the user's next session.Open App and Close App events.You can also log events as out-of-session by setting the session ID to -1. Out-of-session events aren't considered part of the current session. Because they don't extend the current session, they can be useful if you're logging events triggered by push notifications.
Out-of-session events are normally server-side events received by Amplitude (view the HTTP API documentation for more details). These events appear in a user's event stream as disconnected green squares.
By default, Amplitude sorts events into sessions according to session ID. You can also define a session without instrumentation, simply by setting a constant property, custom timeout window, or beginning and ending events to group sessions.
You need Admin or Manager privileges to edit session definitions.
To set a custom session definition, follow these steps:
From the left sidebar, navigate to Settings > Projects.
Click on the project you want to work with.
Click Session Definitions. The Session Definitions modal appears.
Click Custom Session Definition.
Next, choose the specifications for any of three conditions that define the custom session:
Define one condition or multiple conditions, but be aware that all conditions you specify must be met for Amplitude to count a session. If you don't define any of these conditions, Amplitude uses session ID as the session-defining property.
Finally, enter the confirmation phrase and click Save.
Be aware that Amplitude treats combinations of conditions as and logic, meaning all conditions must be met for the session to count. For example, if you want to guarantee that all events in sessions are from the same source, you can do this by using session property and timeout window in tandem:
device ID30 minAlternatively, to define sessions based on in-app usage, you can use starting event and timeout window:
app open5 minSeptember 12th, 2024
Need help? Contact Support
Visit Amplitude.com
