Guides and Surveys Android SDK
Amplitude's Guides and Surveys Android SDK enables you to deploy Guides and Surveys in your Android applications.
This SDK is in Open Beta
This feature is in open beta and under active development.
Requirements
The Guides and Surveys Android SDK requires:
Install and initialize the SDK
Add the following dependencies to your application's build.gradle.kts file:
dependencies {
    // Amplitude Engagement SDK
    implementation("com.amplitude:amplitude-engagement-android:1.0+")
    // Amplitude Analytics SDK (required dependency)
    implementation("com.amplitude:analytics-android:1.+")
Initialize the SDK
import com.amplitude.android.engagement.AmplitudeEngagement
import com.amplitude.android.engagement.AmplitudeInitOptions
// Initialize the SDK
val amplitudeEngagement = AmplitudeEngagement(
    context = applicationContext,
    apiKey = "YOUR_API_KEY",
    options = AmplitudeInitOptions()
// Add the plugin to your Amplitude instance
val amplitude = Amplitude(applicationContext)
amplitude.add(amplitudeEngagement.getPlugin())
Configuration options
Parameter Type Description
apiKey string Required. API key of the Amplitude project you want to use.
initOptions.serverZone EU or US Optional. Sets the Amplitude server zone. Set this to EU for Amplitude projects created in EU data center. Default: US
initOptions.logLevel LogLevel.None or LogLevel.Error or LogLevel.Warn or LogLevel.Verbose or LogLevel.Debug. Optional. Sets the log level. Default: LogLevel.Warn
initOptions.locale string Optional. Sets the locale for localization. Default: undefined. Not setting a language means the default language is used.
Boot the SDK
// Basic boot with user ID
amplitudeEngagement.boot(userId = "USER_ID")
// Advanced boot with options
val bootOptions = AmplitudeBootOptions(
    user = AmplitudeEndUser(
        userId = "USER_ID",
        deviceId = "DEVICE_ID",
        userProperties = mapOf("key" to "value")
amplitudeEngagement.boot(bootOptions)
Enable screen tracking (optional)
Required for screen targeting and the Time on Screen trigger.
// Track screen views to trigger guides based on screens
amplitudeEngagement.screen("HomeScreen")
Enable element targeting (optional)
Pin and tooltip guides require the ability for the SDK to target specific elements on screen.
Jetpack Compose
Use Amplitude Engagement's .amplitudeView modifier to tag Jetpack Compose views. Pass your instance of AmplitudeEngagement as a parameter to .amplitudeView. Configure a CompositionLocalProvider and access it in your view hierarchy or pass your instance as a parameter to your composable views.
// Jetpack Compose Tagging
@Composable
fun MyView() {
    // Use your instance of Amplitude Engagement by creating a Composition context or passing as a param
    val engagement = LocalEngagement.current
    Box {
        Button(
            modifier = Modifier.amplitudeView(
                engagement,
                tag = "my-button",
                onTrigger = {
                    // Optional code to run with tap element action
Non-Jetpack Compose
Guides and Surveys also supports non-Jetpack Compose views. The SDK uses the tag, contentDescription, or resourceName fields to check for a matching selector. You need to set only one of these.
Configure this in your existing layout XMLs or programmatically by setting the properties on the view instance.
<!-- in my_layout.xml -->
<LinearLayout>
    <Button
        <!-- Set either contentDescription or tag to your desired selector -->
        android:contentDescription="my-button"
        android:tag="my-button" />
</LinearLayout>
// Non Jetpack Compose Programmatic Tagging
val button = Button(this)
// Set the contentDescription
button.contentDescription = "my-button"
// Or, set the tag
button.tag = "my-button"
Manage themes
Configure the visual theme mode if your app supports light and dark modes.
// Set the theme mode
amplitudeEngagement.setThemeMode(ThemeMode.DARK) // Options: AUTO, LIGHT, DARK
Router configuration
Configure how Guides and Surveys handles screen navigation.
engagement.setRouter { identifier ->
  // Your screen handling and navigation
identifier String Required. A screen identifier (or route) that tells your app where to navigate.
router (callback) (String) -> Unit Required. A callback you implement to handle screen navigation when Guides or Surveys need to change screens.
Update link behavior
After you configure the router with setRouter(), update the link behavior setting in the Guides and Surveys interface. For any link actions in your guides or surveys, change the behavior to Use router. This ensures that the guide or survey uses the custom router function instead of the default browser navigation.
Reset
Reset a guide or survey to a specific step.
amplitudeEngagement.reset(key = "GUIDE_KEY", stepIndex = 0)
key string Required. The guide or survey's key.
stepIndex number Required. The zero-based index of the step to reset to. Defaults to the initial step.
List
Retrieve a list of all live guides and surveys along with their status.
val guidesAndSurveys = amplitudeEngagement.list()
Show
Display a specific guide or survey. Ignores any targeting rules and limits except for screen targeting.
amplitudeEngagement.show(key = "GUIDE_KEY")
Forward event
If you don't use the plugin, but want to trigger Guides using events, call forwardEvent with any events want to use as triggers.
// Forward events from Amplitude to trigger guides
val event = BaseEvent()
amplitudeEngagement.forwardEvent(event)
Close all
Close all active guides and surveys.
amplitudeEngagement.closeAll()
Simulate Guides and Surveys for preview
To use preview mode to test a guide or survey in your app, configure a custom URL scheme.
Locate the mobile URL scheme
In Amplitude, navigate to your Project's settings.
On the General tab, locate the URL scheme (mobile) field. Copy its value, for example, amp-abc123.
Add the URL scheme in Android Studio
Add the following intent filter to the main activity to your project's AndroidManifest.xml file:
<activity android:name=".MainActivity">
    <intent-filter>
    <action android:name="android.intent.action.VIEW" />
    <category android:name="android.intent.category.DEFAULT" />
    <category android:name="android.intent.category.BROWSABLE" />
    <!-- Add your URL scheme from Amplitude Dashboard here -->
    <!-- ex: android:scheme="amp-12345" -->
    <data android:scheme="<your-unique-scheme-id>" />
    </intent-filter>
</activity>
// In your Activity
override fun onNewIntent(intent: Intent?) {
    super.onNewIntent(intent)
    amplitudeEngagement.handlePreviewLinkIntent(intent)
Changelog
You can access the changelog here.
Was this page helpful?
June 23rd, 2025
Need help? Contact Support
Visit Amplitude.com
