Guides and Surveys React Native SDK
Amplitude's Guides and Surveys SDK enables you to deploy Guides and Surveys on your website or application.
This SDK is in Open Beta
This feature is in open beta and under active development.
Requirements
The Guides and Surveys React Native SDK requires:
Install the SDK
Install the Guides and Surveys React Native SDK as a package with npm or Yarn.
npm install @amplitude/plugin-engagement-react-native
npm install @react-native-async-storage/async-storage
yarn add @amplitude/plugin-engagement-react-native
yarn add @react-native-async-storage/async-storage
Async storage
Explicitly adding @react-native-async-storage/async-storage ensures the native module links correctly, since the engagement native module uses it.
Run pod install in the ios directory.
cd ios
bundle exec pod install
Initialize the SDK
//index.js
import {Linking} from 'react-native';
import { init, add } from '@amplitude/analytics-react-native';
import { getPlugin, handleURL } from '@amplitude/plugin-engagement-react-native';
init('<<< YOUR API KEY HERE >>>');
add(getPlugin());
Linking.getInitialURL().then(async (url) => {
    if (url) {
    const didHandleURL = await handleURL(url);
    if (didHandleURL) { return; }
    // Handle a non-Amplitude SDK URL
Linking.addEventListener('url', async ({ url }) => {
Configure linking
If your app doesn't have deep linking enabled, follow the React Native instructions to add support for deep linking. Previewing Guides and Surveys on a device requires this support.
Locate the mobile URL scheme
In Amplitude, navigate to your Project's settings.
On the General tab, locate the URL scheme (mobile) field. Copy its value, for example, amp-abc123.
Boot the plugin
Booting the plugin (with a user ID) enables Guides and Surveys to be shown:
import {
  track,
  setDeviceId,
  setUserId,
import { useEffect } from 'react';
export default function App() {
  useEffect(() => {
    // setting the User ID in @amplitude/analytics-react-native
    // --and-- passing it to boot() is necessary
    setUserId('rn-test-user-1');
    setDeviceId('test-device-1');
    getPlugin().boot('rn-test-user-1', 'test-device-1');
Changelog
You can access the changelog here.
Was this page helpful?
October 24th, 2025
Need help? Contact Support
Visit Amplitude.com
