Guides and Surveys iOS SDK
Amplitude's Guides and Surveys iOS SDK enables you to deploy Guides and Surveys in your iOS applications.
This SDK is in Open Beta
This feature is in open beta and under active development.
Requirements
The Guides and Surveys iOS SDK requires:
Install and initialize the SDK
Install the Guides and Surveys iOS SDK with Swift Package Manager or CocoaPods.
  1. In Xcode, click File > Add Packages...
  2. Enter the repository URL https://github.com/amplitude/Amplitude-Engagement-Swift
  3. Select the Amplitude-Engagement-Swift package, version 1.0.5.
  4. Click Add Package.
Add the following line to your Podfile, then run pod install.
pod 'AmplitudeEngagementSwift', '~> 1.0.5'
Initialize the SDK
import AmplitudeEngagementSwift
let amplitudeEngagement = AmplitudeEngagement("YOUR_API_KEY")
let configuration = Configuration(
  apiKey: API_KEY
let amplitude = Amplitude(configuration: configuration)
amplitude.add(plugin: amplitudeEngagement.getPlugin())
Configuration options
Parameter Type Description
apiKey string Required. API key of the Amplitude project you want to use.
initOptions.serverZone EU or US Optional. Sets the Amplitude server zone. Set this to EU for Amplitude projects created in EU data center. Default: US
initOptions.logLevel LogLevel.None or LogLevel.Error or LogLevel.Warn or LogLevel.Verbose or LogLevel.Debug. Optional. Sets the log level. Default: LogLevel.Warn
initOptions.locale string Optional. Sets the locale for localization. Default: undefined. Not setting a language means the default language is used.
Boot the SDK
// Basic boot with user ID
amplitudeEngagement.boot("USER_ID")
// Advanced boot with options
let bootOptions = AmplitudeBootOptions(
  user_id: "USER_ID",
  device_id: "DEVICE_ID",
  user_properties: ["key": "value"]
amplitudeEngagement.boot(options: bootOptions)
Enable screen tracking (optional)
// Track screen views to trigger guides based on screens
amplitudeEngagement.screen("HomeScreen")
Enable element targeting (optional)
Pin and tooltip guides require the ability for the SDK to target specific elements on screen. To enable this in your app, give the element a unique identifier.
// Swift UI
MySwiftView {
    // Content
.amplitudeView("MySwiftView", onTrigger: {
    // Optional code to run with tap element action
// UIKit
let myView = MyUIKitView(...)
myView.accessibilityIdentifier = "MyView"
Manage themes
Configure the visual theme mode if your app supports light and dark modes.
// Set the theme mode
amplitudeEngagement.setThemeMode(ThemeMode.DARK) // Options: AUTO, LIGHT, DARK
Router configuration
Configure how Guides and Surveys handles screen navigation.
engagement.setRouter { identifier in
  // Your screen handling and navigation
identifier String Required. A screen identifier (or route) that tells your app where to navigate.
router (closure) (String) -> Void Required. A function (closure) you implement to handle screen navigation when Guides or Surveys need to change screens.
Update link behavior
After you configure the router with setRouter(), update the link behavior setting in the Guides and Surveys interface. For any link actions in your guides or surveys, change the behavior to Use router. This ensures that the guide or survey uses the custom router function instead of the default browser navigation.
Reset
Reset a guide or survey to a specific step.
amplitudeEngagement.reset(key = "GUIDE_KEY", stepIndex = 0)
key string Required. The guide or survey's key.
stepIndex number Required. The zero-based index of the step to reset to. Defaults to the initial step.
List
Retrieve a list of all live guides and surveys along with their status.
val guidesAndSurveys = amplitudeEngagement.list()
Show
Display a specific guide or survey. Ignores any targeting rules and limits except for screen targeting.
amplitudeEngagement.show(key = "GUIDE_KEY")
Forward event
If you don't use the plugin, but want to trigger Guides using events.
amplitudeEngagement.forwardEvent([
  "event_type": "my event type",
  "event_properties": [String: String]()
Close all
Close all active guides and surveys.
amplitudeEngagement.closeAll()
Simulate Guides and Surveys for preview
To use preview mode to test a guide or survey in your app, configure a custom URL scheme.
Locate the mobile URL scheme
In Amplitude, navigate to your Project's settings.
On the General tab, locate the URL scheme (mobile) field. Copy its value, for example, amp-abc123.
Add the URL scheme in Xcode
  1. Open your iOS project in Xcode.
  2. In the Project navigator, select your app's target.
  3. On the Info tab, locate the URL Types section.
  4. Add a new URL type with the following values:
    • Identifier: Provide a descriptive name, like AmplitudeURLScheme.
    • URL Schemes: Paste the value you copied from Amplitude, for example amp-abc123.
// In your AppDelegate or SceneDelegate
func application(_ app: UIApplication, open url: URL, options: [UIApplication.OpenURLOptionsKey : Any] = [:]) -> Bool {
    if amplitudeEngagement.handleUrl(url) {
        return true
    // Handle other URL schemes
    return false
Changelog
You can access the changelog here.
Was this page helpful?
June 23rd, 2025
Need help? Contact Support
Visit Amplitude.com
